| comentario del autor | Mie May 26, 2004 6:14 pm | |
en win98 se instala pero da un error durante su instalacion. Luego tiene un fal funcionamiento. en xp directamente me anula la instalación y me da un error: driver_irql_not_less_or_equal la pc es nueva y el disco es de 40Gb, procesador celeron. Está bien que le haga un formato fat32 para xp????. Desde ya muchas gracias. |
| sin valorar | Mie May 26, 2004 7:38 pm | |
Bug Check 0xD1: DRIVER_IRQL_NOT_LESS_OR_EQUAL The DRIVER_IRQL_NOT_LESS_OR_EQUAL bug check has a value of 0x000000D1. This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high. Parameters The following parameters are displayed on the blue screen. Parameter Description 1 Memory referenced 2 IRQL at time of reference 3 0: Read 1: Write 4 Address that referenced memory Cause A driver tried to access an address that is pageable (or that is completely invalid) while the IRQL was too high. This bug check is usually caused by drivers that have used improper addresses. Resolving the Problem To begin debugging, use a kernel debugger to get a stack trace. |
| sin valorar | Jue May 27, 2004 1:26 am | |
el error te indica un fallo de volcado de pila, que posiblemente te indique que tu memoria o el procesador esten fallando.. checalos posiblemente tengas que cambiar algunas caracteristicas de tu procesador en labios de tu mother board..ojala te haya ayudado |
| sin valorar | Mar Jun 01, 2004 3:24 pm | |
