impresora cannon 600 aparentemente no reconoce el cabezal
comentario del autor Mie Oct 13, 2004 8:32 pm
amigos resivan un cordial saludo, aver si alguno de ud. me puede ayusar sobre este problema que tengo con unas impresoras.
canon 600. cuando lo prendo aparentemente se queda osilando el led de encendido por unrato lugo bota un pitido y se pone en error o talvez quedra para resetearlo
les agradesco su respuesta
Misael
asistió a la solución Jue Oct 14, 2004 12:27 am
BJC-600 & BJC-600E
Nozzle pattern test
Printer off
Press and hold on line then power on
Release after power led flashes
When led stops flashing printing starts
To stop turn power off
Self test
Power off
Press and hold FF and press and hold power until power led flashes then release both
Press and release on line.
Font test
Power off
Press and release print mode
Reset counter
Turn printer off and unplug from the back
Press and hold the print mode, FF & power then reconnect power
When a musical note is heard release the buttons
The head will dance and then go to normal operation.
Calibration (after changing anything on the carriage)
Press and hold the print mode & power reconnect power
Wait a few seconds then turn power off
Eprom is now updated.
Test print a. (after performing any repair)
Power off.
Press FF, on line, print mode, thick and power buttons.
When beeper sounds release all.
Press FF to enter service mode.
Press on line button to start test.
Flushing (Head Cleaning)
Power off.
Press print mode three times.
Press on line to flush.
To flush again press on line twice.
Power off to exit.
Perform test print.
Error Codes
2 Beeps-Error light on-Paper jam / Waste ink full / Ink out error
3 Beeps-Error light flashing-Carriage error / Home position error / Encoder error / Recovery error / Feed motor error / Sheet feeder home error / Internal temp error / Waste ink error / E-Prom error / ROM Error / RAM Error / Gate array error
3 Beeps-Error/Envelope/Thick lights flashing-Print head error
Sergio de chaco argentina
sergio25
