desbloquear epson stylus c110
comentario del autor Mar Dic 11, 2007 3:59 pm
hola saben ya baje el ssc 4.2 y el 4.3 y no esta la epson stylus c110 sabe que puedo hacer o como bajar un resteador para desbloquer mi impresora les pido su ayuda porfavor
marcpin9
comentario del autor Mie Dic 12, 2007 1:02 pm
hola nadia me puede ayudar con mi problema porfavor un comentario una esperanza de como restaer mi epson
marcpin9
comentario del autor Mie Dic 12, 2007 5:27 pm
alguien sabe algo de como desbloaquear mi impresora es la eoson stylus C110
marcpin9
sin valorar Jue Oct 02, 2008 11:31 am
pues nadie sabe aun quieres que les paguews primero
pues yo ando en las mismas
willicl
sin valorar Mar Mar 31, 2009 1:29 pm
Hola, esto es lo que encontre !!
Reset procedure for Epson C110 almost the same as reset Epson C90 or Epson C79. Date setting must be used in the PC for software resetter Epson C110 is 11 April 2008.
Before run resetter for epson c110, change date setting in your computer to run adjustment program for Epson C110 without error, its way :
Click Start then select Control Panel. In control panel windows appears select date and time (classis view). If control panel in your computer is category view select “date, time, language, and regional setting” then select date and time, or to open date and time setting quickly double click the clock in the system tray (systray).
Then change date setting in the computer to to 11 April 2008
Here Steps by Steps to resetting waste ink counter pad Epson C110 :
Download software resetter untuk Epson C110
Ekstrak resetter for Epson C110
Turn on the printer.
Run adjustment program for Epson C110 “AdjProg.exe” file. then Click “Accept”.
Select “Particular adjustment mode”.
Then select Waste Ink pad Counter then click OK.
Click Check button, to read waste ink counter pad, the await til finish.
Click Initialization button to reset waste ink counter pad to 0 then click Finish.
Turn the printer off the turn on again.
Once the process the printer should be normal again.
To view the result test print the printer.
Here link to download Adjustment program for Epson C110 (resetter Epson C110
Link de descarga :
http://www.4shared.com/file/52036502/48b1bf3/Resetter_Epson_C110.html
saludos y suerte
dreamsemcast
sin valorar Lun Nov 02, 2009 3:36 pm
Muchas Gracias Amigo te pasaste, me funko al 100% tu ayuda!
Gracias.. Wink
stev_35
