CANON S330
comentario del autor Lun Oct 04, 2004 4:16 pm
Tengo un problema con una impresora s330 que me tira un mensaje
que el deposito de tinta usada esta lleno y no me imprime, que hago por favor si alguien me puede ayudar
Salu2
jmatalsol
sin valorar Sab Oct 09, 2004 3:21 pm
ME PARECE QUE SOLO ES UN RESETEO FISICO DE LA MAQUINA , ESTO SI LA MAQUINA CENTELLEA SU LED ROJO VERDE , SI ES ASI EL RESETEO LO CONSIGUES EN INTERNET .
daniel isaias
sin valorar Sab Oct 09, 2004 9:11 pm
A ver Fijate esta informacion... Sergio de Chaco - Argentina
GENERIC “S” SERIES RESET CODE.
This reset is an emailed submission. But the person who sent it in requested their name to be withheld.
This reset is for the S series printers. This does look like the same reset for the S9000 but has a little more detail.
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will “reset" or move momentarily.
If the above was properly performed the printer will enter the "Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM – Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point – However it is best leave them unaltered – You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
sergio25
comentario del autor Mar Oct 12, 2004 3:31 pm
Gracias por su respuesta
Ya la resete pero ahora meda un mensaje que dice que el cartucho es desconocido y no se puede establecer comunicación con la impresora, que rev si esta conectada y claro que esa conectada que otra cosa le podria hacer?
jmatalsol
sin valorar Mar Oct 12, 2004 7:42 pm
fijate si esta bien configurado en tu sistema operativo el puerto de comunicacion con tu impresora, despues fijate la placa controladora LPT1 u/o USB (no se en que puerto de comunicacion tendras).-
y sino no se que puede ser, el cartucho esta en buen estado?
el cartucho tiene algun chip?
Sino algo en la placa madre, algun conector que va hacia al cabezal, algo de eso...
fijate va....., revisa todo lo que te indico y anda eliminando ipotesis...
sergio de chaco - argentina
sergio25
