xerox xe-80
comentario del autor Sab Nov 20, 2004 5:23 pm
hola , a todos
tengo problema con esta maquina alguien podria enviarme el manual de servicio, tambien tengo una canon np-1010 ,yo soy especialista en fotocopiadora sharp ,cualquier consulta estoy para servirle.
miguelpg88
sin valorar Mar Nov 23, 2004 2:38 pm
Que problema talvez te pueda ayudar
Francisco Solano
sin valorar Mie Nov 24, 2004 1:22 pm
que problema tienes?
lenin cuenca
sin valorar Mie Nov 24, 2004 6:05 pm
yo tengo el manual de la canon 1010 pero lo tengo en papel, pero que problema tienes con el equipo
Aficio(eulides)
sin valorar Vie Dic 31, 2004 6:44 am
STATUS CODES:
Note: Press the ‘Print’ Button to view a subcode…
CH Toner Cartridge not present or not seated properly
C1 Front Door Open
E1 Paper Jam / Misfeed
E2 Paper Jam
E3 Paper Jam (on exit)
E7-03 Laser Output error
E7-04 CCD (‘Charge Coupled Device’ or scanning device) white level error
E7-05 CCD black level error
E7-12 CCD shading level error
E7-14 ASIC communication error (try clearing by turning off & on)
E7-15 Copy Lamp problem
H2 Thermistor Open
H3 High fuser temperature
H4 Low fuser temperature
J2* Drum Cartridge end of life
L1 Mirror Base did not leave home position
L3 Mirror Base did not return to home position after copy cycle
L4 Main motor problem
L6 Polygon motor (drives the laser) problem
P Paper feed problem (Paper didn’t reach the paper feed sensor in time)
U2-01 Counter Memory Data failure
U2-04 Memory Failure
DIAGNOSTICS:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go totally blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To Reset the Drum Count: Open the front door. Then hold down the Copy Contrast Key while closing the front door… continue to hold the ‘Copy Contrast’ button for at least 3 seconds until the 3 Copy Contrast indicators blink & the console comes to ready. The drum count is reset to zero and the machine will run another 18,000 copies before calling J2 again.
To read Copy Count: Press & hold the ‘Clear’ key… the display will flash the total copy count 2 digits at a time.
HECTORRI
