| comentario del autor | Jue May 17, 2007 10:29 pm | |
yo me dedico a minolta pero se casi nada de xerox , es porello que pido su apoyo . de antemano les agradeco su amable atencion¡¡¡¡¡¡ |
| sin valorar | Vie May 18, 2007 8:03 am | |
XC810 style DRUM CARTRIDGE RECONDITIONING INSTRUCTIONS XC810, XC811, XC820, XC822, XC830, XC855, XC865, XC875 XC1020, XC1033, XC1040, XC1044, XC1045, XC1245, XC1255 (Also Sharp Z-810 series) INTRODUCTION: The drum cartridge is the same for all of the XC800,1000,1200 series machines. These machines are unique in the way they reset the drum count. On the rear of a new cartridge is a gear-like piece with a flag which swings down during initialization and trips a photo-sensor to reset the drum count. One warning... the first cartridge which the customer gets with the purchase of a new machine is a 'starter' cartridge and is not equipped with the drum count reset mechanism. Fortunately, the drum count can also be reset from diagnostics. I’ll explain both of these ways in the procedure. The cartridge will run 12,000 copies before the machine calls for a new one. It remains to be seen if the drums on these cartridges are hardy enough to run a second cycle without failing. SECTION I: TOOLS AND SUPPLIES Tools you’ll need: Philips-Head Screwdriver #2 Small Flat-Head Screwdriver Supplies you may need: Starter Powder (dusting pouch) Yellow Dust Cloths White Polishing Sponge (optional) Drum-Coat Polish (optional) Replacement components which you may need: Replacement Drum Replacement Cleaning Blade SECTION II: PROCEDURE 1.) First check the drum for flaws (turns counter-clockwise if you’re looking at the rear end)... If the drum is still in good shape, you may choose to polish it & use it for a second cycle. 2.) Turn the front drum hub 1/4 turn clockwise and then extract it. The drum can then be lifted out of its cradle. This drum is light sensitive so store it in a dark place. 3.) Remove the two rear metal contacts (1 screw each from the top). Then remove the charge corotron (2 silver screws). 4.) Remove the Cleaning Blade (5 screws). Inspect the blade for imperfections and deterioration. Replace the Blade if needed. Use fresh drum starting powder on the blade. 5.) Vacuum & clean everything thoroughly. Be careful not to damage the scorotron grid and the thin mylar recovery blade. The front end-cap is held in place by 3 clips... take notice of the position of the 3 gears which drive the auger system... they are loose under the front end cap and will fall off easily. Slide back the shutter on the top of the auger tube & vacuum any excess toner out. 6.) Drum Count Reset: Remove the Drum Count Reset Mechanism (the white gear-like piece... see illustration #2) from its shaft on the rear of the cartridge (1 clip). If you do not see this piece, read the Note below. Reposition the Reset Mechanism so that the flag is at around 1 o’clock as shown in Illustration #2 & re-install the clip. NOTE: If the cartridge you are working on is a ‘Starter’ Cartridge (the one the customer gets with the purchase of the machine)... it will be missing the Reset Mechanism. In this case, you can reset the Drum Count from Diagnostics as follows: (24-7) A) Enter Diagnostics... this is done by turning on the machine and then, within 4 seconds, press ‘Clear’, Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). All of the display will go blank. B) Select ‘24’ using the copy quantity buttons, then press ‘Print’, then select ‘7’ and press print again. This will reset the drum count to ‘0’. 7.) Reassemble the cartridge. Install the blade, the corotron, and the 2 metal contacts (the wire from the corotron goes through a hole in the plastic & under the forward most contact, the screw goes through the loop in the wire). Apply Fresh Drum Starting Powder to the drum & Blade (we have found the starting powder which new generic drums come with to be completely inadequate in this model, so remove the old starting powder & apply fresh stuff). Re-install the Drum & Front Drum Hub. Turn the drum (counter-clockwise looking at the rear end) to make sure it turns ok and that the cleaning blade is working properly. FINISHED ! -------------------------------------------------------------------------------- RELATED DIAGNOSTIC PROCEDURES: ENTERING DIAGNOSTICS: Turn on the machine and then, within 4 seconds, press ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (the ‘Exposure Mode’ button is the one on the far left). All of the display will go blank. DRUM RESET (24-7) Enter diagnostic mode as explained above. Select ‘24’ using the copy quantity buttons, and press ‘Print’, then select ‘7’ and press ‘Print’ again. This resets the drum count to ‘0’. Turn off power to exit diagnostics. READING DRUM CARTRIDGE COUNT (22-12) To see how many copies a cartridge has run... enter diagnostics and select ‘22’ using the copy quantity buttons, then press ‘Print’, then select ‘12’ and press ‘Print’ again. The copy count will flash, 2 digits at a time (Ex: ‘00’ followed by ‘05’ followed by ‘67’ would mean 567 copies). Press ‘Clear’ to exit diagnostics. STATUS CODES: A1 SDF Document Jam A2 SDF Document Jam CH Toner Cartridge not present or not seated properly H2 Thermistor Open H3* High fuser temperature H4* Low fuser temperature L1 Scanner carriage did not leave home position on power up or upon pressing start L3 Scanner carriage did not return to home position after copy cycle L4 Main motor problem L5 Lens did not leave home after power up or upon selecting reduction or enlargement P Paper feed problem (Paper didn’t reach the paper feed sensor in time) U2** Memory failure U5 SDF high temperature (or SDF thermistor failure) DIAGNOSTICS: To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank. To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again. To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off. *To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics. **To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics. Testing Switches & Sensors: (Input Component Codes) In diagnostic mode, enter the code for the component, press ‘Print’, then manually actuate the switch or sensor and watch for the Ready Lamp to turn on & off. Code Component Control Console Lamp to watch 1-2 Scan Home Sensor Drum Cartridge Lamp 2-2 Document Feed Sensor Toner Cartridge Lamp 2-2 Docmunet Sensor Paper Jam Lamp 2-2 Document Exit Sensor Drum Cartridge Lamp 2-2 SDF Interlock Sensor SDF Jam Lamp 30-1 Paper Exit Sensor Drum Cartridge Lamp Checking Clutches, Motors, Lamps, Solenoids & Corotrons: (Output Component Codes) Use these codes to test a component such as a clutch or motor. Enter the code followed by ‘Start’ to activate a component. Most components activate for 1 second (Exposure lamp lights for 30) Code Component 1-1 Scan Drive Motor - The first time ‘Print’ is pressed, optics move into home position... Then select the magnification you want to observe... the second time ‘Print’ is pressed, optics scan at the speed corresponding to the magnification selected. - The Drum Cartridge Lamp should light whenever the scanner reaches the home position. 1-3 Lens Motor - Lens steps through each magnification once. 1-4 Lens Motor - Lens steps through each magnification repeatedly until ‘Clear’ is pressed. 2-3 SDF Motor - SDF Motor rotates for 10 seconds at a speed corresponding to the selected magnification after ‘Print’ is pressed twice. 2-4 Document Feed Solenoid - Solenoid turns on for 10 seconds. 2-5 Document Registration Clutch - Registration Roll Clutch turns on for 10 seconds each time ‘Print’ is pressed. 5-1 Control Panel Lamps - Half of the console lamps light each time ‘Print’ is pressed. 5-2 Fuser Lamp - Press ‘Print’, lamp pulses on 5 times. 5-3 Exposure Lamp - Lamp lights for 5 seconds each time ‘Print’ is pressed. 5-4 Discharge Lamp - Lamp lights for 30 seconds each time ‘Print’ is pressed. 5-5 Side Erase Lamp - Each time ‘Print’ is pressed, each Side Erase Lamp lights in sequence, then all stay on for 10 seconds. 10 Toner Motor - When ‘Print’ is pressed, motor runs for 30 sec. 25-1 Main Motor - When ‘Print’ is pressed, motor runs for 30 sec. Checking the Total Copy Count:(22-5) Enter diagnostics, select ‘22’, ‘Print’ followed by ‘5’, ‘Print’...The copy count will flash 2 digits at a time for a total of six digits (for example: 01 23 45 would indicate 12,345 copies). (Can also be done by the customer by holding the ‘Clear’ button for 7 seconds) Checking the Drum Cartridge (CRU) Count:(22-12) Enter diagnostics, select ‘22’, ‘Print’ followed by ‘12’, ‘Print’...The copy count will flash 2 digits at a time for a total of six digits (for example: 00 23 45 would indicate 2,345 copies). Drum Count Reset:(24-7) Enter diagnostics, select ‘24’, ‘Print’, followed by ‘7’,’Print’, followed by ‘Print’ again. This resets the drum count to zero.For information on reconditioning the drum cartridge... check out the Instructional PARA RESET DEL DRUM: realiza esta secuencia rapidamente: luego de los 4 primeros pasos el visor de cuenta copias se apagara y alli debes seguir con los pasos 24 print 07 print apaga y enciendes los numeros los introduces con las ▲ y ▼... cancelar/auto exposicion/cancelar/auto exposicion/24/print/07/print /off/on Drum Cartridge Life End Disable/Enable:(27) Enter diagnostics, select 27, ‘Print’...The current drum life configuration will be displayed. ‘0’=End of life disabled, ‘1’=End of life enabled. Select the configuration you want and press ‘Print’. Then exit diagnostics. If you choose to disable the drum end of life warning, inform the customer that they’ll need to watch copy quality to know when it’s time to replace the Cartridge. Adjusting the Developer Bias: Remove the rear cover. . Connect the ‘+’ side of your meter from the blue DV Bias Terminal on the upper right corner of the High Voltage Power Supply (HVPS) and the ‘-’ side to the chassis. Enter diagnostics… Select Code 8-1... When ‘Print’ is pressed, the Developer Bias will be present for 30 seconds. Adjust by turning VR201 on the HVPS for a voltage of -150 VDC +/- 10 VDC. Adjusting the Grid Bias: Remove the rear cover. Connect ‘+’ to the ‘GB’ terminal on the lower left of the HVPS & ‘-’ to the chassis. Enter diagnostics... Select Code 8-2... When ‘Print’ is pressed, the Grid Bias (for ‘Normal’ mode) will be present for 30 seconds. Adjust VR301 on HVPS for a voltage of -650 VDC +/-13 VDC. Select Code 8-3... When ‘Print’ is pressed, the Grid Bias (for ‘Toner Save’ mode) will be present for 30 seconds. Adjust VR301 on HVPS for a voltage of -500 VDC +/-10 VDC. Select Code 8-4... When ‘Print’ is pressed, the Grid Bias (for ‘Photo’ mode) will be present for 30 seconds. Adjust VR301 on HVPS for a voltage of -400 VDC +/-8 VDC. Fuser Temperature Adjustment:(43-1) Enter diagnostics... Enter ‘43’,’Print’...1’,’Print’... the current setting will be displayed. 0=170 (default)... 1=175...2=180...3=185...4=190...5=195. If you want to change the setting, use the copy quantity button & press ‘Print’ to lock in your selection. Fuser Temperature Adjustment for Multiple Copy Runs:(43-2) After 20 copies, the machine is designed to lower the fusing temperature to a preset value. Enter diagnostics... Enter ‘43,’Print’...’2’,’Print’... the current setting is displayed. 0=160...1=165 (default)...2=170...3=175...4=180...5=185. Change using the copy quantity select button & press ‘Print’ to lock in your selection. Exposure Adjustment:(47 & 46-1…for SDF=51-6) Should be done after replacing Exposure lamp, Exposure Sensor, Exposure PWB, or Main PWB First clean all optics & align the "Exposure Plates" on the Exposure Lamp Carriage so that the copy is evenly exposed. Cover the entire document glass with blank copy paper & close the cover. Enter diagnostics & select ‘47’ (adjusts the "White Reference Level"). The display shows a hex code which represents the current setting, the exposure lamp carriage moves to the measuring position. Press ‘Print’… the lamp lights & the display indicates the new hex code. Press ‘Clear’ to exit the ‘47’ diagnostic code. Then select ‘46’, ‘Print’, ‘1’, ‘Print’… Place a Test Pattern on the glass, select the copy mode (Text, Photo, or Toner save) & the copy contrast (Light, Mid, or Dark) you wish to adjust… Press ‘Print’ to run a copy. The current exposure level is displayed. Increase the number shown (range is from 00 to 99) to increase exposure (lighter copy). Decrease the number shown to darken the copy. For SDF Exposure adjustment, follow same procedure but use the diagnostic code ‘51’, ‘Print’, ‘6’ ‘Print’ instead of the 46-1 shown above. Magnification Adjustments:(48-1) Ranges are from 00 to 99, Default=50. "Front to Rear" magnification: (adjusts the position of the lens) Enter diagnostics, select ‘48’, ‘Print’, ‘1’, ‘Print’. Press the ‘Exposure Mode’ button until only the ‘Auto’ lamp is lit. Adjust up to increase magnification, down to decrease. Exit diagnostics. ."Lead Edge to Trail Edge" magnification: (adjusts the scan speed) Enter diagnostics and select ‘48’, ‘Print’,’1’, ‘Print’. Press the ‘Exposure Mode’ button until only the ‘Auto’ and ‘Text’ lamps are lit. Adjust the number shown up to increase magnification or down to decrease. Exit diagnostics. "SDF Lead Edge to Trail Edge" magnification: (adjusts document speed) Same procedure but press the ‘Exposure Mode’ button until "Auto, Manual & Photo" lamps light. Registration & Deletion Adjustments:(50-1) Ranges are 00 to 99, Default=50 Lead Edge Registration:(changes the timing of the sheet) Enter diagnostic code ‘50’, ’Print’, ’1’, ’Print’… press ‘Exposure’ and ‘Contrast’ buttons until ‘Auto’ & ‘Normal’ lamps are lit… Increase number shown to decrease the distance between the lead edge & the image. SDF Lead Edge Registration: Same as above but press ‘Exposure’ and ‘Contrast’ buttons until ‘Auto’, ‘Manual’, & ‘Photo’ lamps are lit to make your changes. Lead Edge Deletion: Enter diagnostics, select ‘50’, ‘Print’, ‘1’, ‘Print’. Press ‘Exposure’ and ‘Copy Contrast’ buttons until only the ‘Auto’ & ‘Light’ lamps are lit… adjust number shown up to increase deletion… down to decrease. Trail Edge Deletion: Enter diagnostic code 50-1… press ‘Exposure’ and ‘Contrast’ buttons until ‘Auto’ & ‘Dark’ lamps are lit… adjust number shown up to increase, down to decrease. Registration Buckle: (51-2) Ranges from 00 to 99… Default=14 (140ms) Paper Tray Registration Buckle: Enter diagnostics, select ’51’, ‘Print’, ‘2’, ‘Print’…press the ‘Exposure’ button until only the ‘Auto’ lamp is lit. Use copy quantity buttons to change setting 1 step = 10 ms (microseconds). Alternate Tray Registration Buckle: same as above but press the ‘Exposure’ button until only the ‘Auto’ & ‘Text’ lamps are lit. SDF Tray Registration Buckle: same but press the ‘Exposure’ button until the ‘Auto’, ‘Manual’, & ‘Photo’ lamps are lit. Configuration Codes: to display & change various machine configurations… to change, select new number with copy quantity buttons, then press ‘Print’ Code: Function: Range: Default: Details: 26-1 Tray Configuration 0 or 1 - 0 = Single Sheet Bypass 1 = Alternate Tray 26-2 SDF Configuration 0 or 1 - 0 = Without SDF 1 = With SDF 26-3 2nd Tray Setting (XC 1250/1255 Only) 0 or 1 - 0 = 1 Tray 1 = 2 Tray 26-6 Paper Size Type 0 or 1 - 0 = Inch Series 1 = AB Series 26-7 Machine Conditions Check Shows voltage setup & Copies per Minute setup. - - For all machines, Jam Indicator light is on… Current machine conditions are displayed as follows: 100v = Auto lamp on 120v = Auto/Text lamps on 200v = Auto/Text/Photo on 8CPM = ‘8’ displayed 10CPM = ‘10’ displayed 12CPM = ‘12’ displayed 26-11 Drum Life Correction Adjustment 0 – 5 2 Exposure Lamp voltage increases after 3000 copies 0 = No Correction 1 = 0.33 Volts AC 2 = 0.66 Volts AC 3 = 0.99 Volts AC 4 = 1.32 Volts AC 5 = 1.65 Volts AC SPECIFICATIONS: Manufacturer: SharpÒ Corporation also sold as Z-850 & similar model #’s. Copies/Minute: 800 series is set up for 8CPM, 1000 series = 10CPM, 1200 series = 12CPM Logical, with the exception that XC1245/55 w/SDF is set for 10CPM Suggested Retail Price: Ranges from $800.- for XC810 to $425.- for XC1255 w/ SDF Zoom Capabilities: 70-141%… Presets = 70, 78, 86, 100, 129, 141 Paper Sizes: Copy Paper from Paper Tray 1 or 2: (16-24 lb.) 8.5x5.5" To 8.5x14" Copy Paper from Bypass (14-34 lb.) 3.5x5.5" To 8.5x14" SDF Document Paper: (16-24 lb.) 5.5x8.5" To 8.5x14" First Copy Time: 8 seconds (warm)… 20 seconds (cold)… Warm up Time: None. Yields: Drum Cartridge: 12,000 (gives a 1000 copy warning light) Toner Cartridge: 4,000 (Assumes average area coverage of 6%...Regular full page of text) en este post puedes encontrar un instructivo de como recargar estos modulos(no es del modelo especifico) pero te puede sevir.. http://www.yoreparo.com/foros/reparacion_de_fotocopiadoras/78478.html saludos y suerte |
| sin valorar | Vie May 18, 2007 2:04 pm | |
| sin valorar | Vie May 18, 2007 2:11 pm | |
