www.YoReparo.com
Xerox XC 1040 insumos compatible
comentario del autor Jue Jun 26, 2008 3:56 pm
No logro conseguir suministros como :
Drum fotoconductor
lamina de limpieza
revelador
toner
rrodillos fusores
cre que esta maquina es compatible con Sharp 845
gracias de antemano,
Ser2958
solución Jue Jun 26, 2008 6:29 pm
Hola :
Es igual a Xerox XC 1245 y Sharp Z 845
Xerox XC1040 Drum
DRUM - Drum Only - With Gear
For Use In: Sharp Z820, Sharp Z835, Sharp Z845, Xerox XC1020, Xerox XC1040, Xerox XC1044, Xerox XC1045, Xerox XC1255, Xerox XC810, Xerox XC820, Xerox XC830, Xerox XC855, Xerox XC865
Xerox XC1040 Blade / Brush
DRUM - Cleaning Blade
For Use In: Xerox 5201, Xerox 5203, Xerox 5305, Xerox 5306, Xerox XC1020, Xerox XC1040, Xerox XC1044, Xerox XC1045, Xerox XC1255, Xerox XC355, Xerox XC356, Xerox XC810, Xerox XC820, Xerox XC830, Xerox XC855, Xerox XC865
Xerox XC1040 Developer
DEVELOPER - Compatible - Refill - 165 Gram Bottle
For Use In: Xerox XC1020, Xerox XC1040, Xerox XC1044, Xerox XC1045, Xerox XC1255, Xerox XC810, Xerox XC820, Xerox XC830, Xerox XC855, Xerox XC865
Xerox XC1040 Toner Refill
TONER - Compatible - Refill - 170 Gram Bottle - Our refill toner is intended for use by professional refillers only.
For Use In: Xerox XC1020, Xerox XC1040, Xerox XC1044, Xerox XC1045, Xerox XC1245, Xerox XC1255, Xerox XC810, Xerox XC820, Xerox XC830, Xerox XC855, Xerox XC865
Xerox XC1040 Fuser Roller
FUSER - Upper Fuser Roller
Xerox XC1040 Corona / Charge / Transfer
CORONA - Wire - 70 Micron Oxidized - All Applications - 50 Meter Spool
For Use In: Imagistics (Pitney Bowes) L400, Imagistics (Pitney Bowes) L415, Lanier 5216, Lanier 5220, Lanier 6113, Lanier 6213, Lanier 6413, Lanier 6514, Lanier 6610, Lanier 6614, Lanier 6714, Lanier 6716, Lanier 6718, Lanier 7214, Lanier 7216, Lanier 7314, Lanier 7385, Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1600, Sharp AL1610, Sharp AL1620, Sharp AL1621, Sharp AL1640, Sharp AL1641CS, Sharp AL1650, Sharp AL1651, Sharp AL1651CS, Sharp AL1661, Sharp AL1670, Sharp AR150, Sharp AR150E, Sharp AR150N, Sharp AR151, Sharp AR153E, Sharp AR155, Sharp AR155N, Sharp AR156, Sharp AR157E, Sharp AR160, Sharp AR161, Sharp AR162, Sharp AR162S, Sharp AR163, Sharp AR164, Sharp AR168D, Sharp AR168S, Sharp AR200, Sharp AR201, Sharp AR205, Sharp AR206, Sharp AR207, Sharp AR250, Sharp AR280, Sharp AR281, Sharp AR285, Sharp AR286, Sharp AR287, Sharp AR335, Sharp AR336, Sharp AR337, Sharp AR405, Sharp AR407, Sharp AR501, Sharp AR5015, Sharp AR505, Sharp AR507, Sharp AR5125, Sharp AR5132, Sharp AR5316, Sharp ARF151, Sharp ARF152, Sharp ARF201, Sharp ARM160, Sharp ARM162, Sharp ARM205, Sharp ARM207, Sharp CX7500, Sharp CX7700, Sharp DM2000, Sharp FO3300, Sharp FO4900, Sharp FO5000, Sharp FO5200, Sharp FO5210, Sharp FO5220, Sharp FO5300, Sharp FO6000, Sharp FO6100, Sharp JX9300, Sharp JX9500, Sharp JX9500H, Sharp JX9700, Sharp SD2060, Sharp SD2175, Sharp SD2260, Sharp SD2275, Sharp SD3062, Sharp SD4085, Sharp SF2010, Sharp SF2014, Sharp SF2020, Sharp SF2022, Sharp SF2022N, Sharp SF2025, Sharp SF2027, Sharp SF2027N, Sharp SF2030, Sharp SF2035, Sharp SF2040, Sharp SF2050, Sharp SF2052, Sharp SF2114, Sharp SF2116, Sharp SF2118, Sharp SF2120, Sharp SF2214, Sharp SF2216, Sharp SF2314, Sharp SF2414, Sharp SF2514, Sharp SF2530, Sharp SF2540, Sharp SF6000, Sharp SF7200, Sharp SF7300, Sharp SF7320, Sharp SF7350, Sharp SF7370, Sharp SF750, Sharp SF755, Sharp SF756, Sharp SF770, Sharp SF7700, Sharp SF771, Sharp SF7750, Sharp SF780, Sharp SF7800, Sharp SF781, Sharp SF7850, Sharp SF7855, Sharp SF7900, Sharp SF8100, Sharp SF8200, Sharp SF8260, Sharp SF8300, Sharp SF8350, Sharp SF8400, Sharp SF8500, Sharp SF8570, Sharp SF8600, Sharp SF8800, Sharp SF8870, Sharp SF8875, Sharp SF9100, Sharp SF9300, Sharp SF9400, Sharp SF9500, Sharp SF9510, Sharp SF9550, Sharp SF9560, Sharp SF9600, Sharp SF9700, Sharp SF9750, Sharp SN1420, Sharp SN1430, Sharp SN1610, Sharp SN1810, Sharp SN2010, Sharp SN2030, Sharp Z30, Sharp Z50, Sharp Z52, Sharp Z57, Sharp Z60, Sharp Z70, Sharp Z72, Sharp Z75, Sharp Z76, Sharp Z77, Sharp Z800, Sharp Z820, Sharp Z835, Sharp Z845, Sharp Z85, Toshiba E STUDIO 12, Xerox 5008RE, Xerox 5008S, Xerox 5220, Xerox 5260, Xerox 5309, Xerox 5614, Xerox 5614Z, Xerox 5614ZSD, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: DWIR-0466CSZZ
exito
Luis
PR
LACTECH
comentario del autor Jue Jun 26, 2008 7:19 pm
Luis :
espero que te encuentres bien al igual que tu familia
de nuevo gracias por la informacion .
te deseo lo mejor.
exitos !
Ser2958
