| comentario del autor | Mar Ago 05, 2008 8:32 am | |
| solución | Mar Ago 05, 2008 10:53 pm | |
Te envios los codigos referente a esa area. Por lo que se refiere tienes un problema con el motor de la corchete en el Finisher, limpia los rieles de desplazamiento lubrica con un poco de aceita los bujes y verifica el sensor de parada atte Raul Nuñez E7: Optional Unit Error Code Function Check Points E7- 20 Finisher Paper Transport Motor See Sect. E7- 21 Finisher Paper Exit Motor E7- 22 Finisher Damper Motor E7- 23 Finisher Staple Motor E7- 24 Finisher Staple Sift Motor E7- 25 Finisher Paper Height Sensor E7- 26 Finisher Backup RAM Data E7- 27 Finisher Tray Lift Motor E7- 28 Finisher Punch Motor E7- 29 Finisher Punch Shift Motor E7- 40 Finisher Saddle-Stitch Communication E7- 41 Finisher Saddle Positioning Plate Motor E7- 42 Finisher Saddle Folding Motor E7- 43 Finisher Saddle Guide Motor E7- 44 Finisher Saddle Alignment Motor E7- 45 Finisher Saddle Rear Staple Motor E7- 46 Finisher Saddle Front Staple Motor E7- 47 Finisher Saddle Push Motor E7- 48 Finisher Swing Motor E7- 49 Finisher Sensor Connector E7- 50 Finisher Micro Switch E7- 51 Finisher Delivery Motor . E7- 52 Finisher Paddle Motor For DA-FS355/355A, DA-SP41 only. E7- 53 Finisher Saddle Folding Sensor E7- 54 Finisher Punch Communication E7- 55 Finisher Punch Power Supply E7- 56 Finisher Punch Registration Sensor E7- 57 Finisher Punch Sensor (Horizontal Registration) E7- 58 Finisher Punch Sensor (Waste |
