| comentario del autor | Vie Jun 27, 2008 4:17 pm | |
| solución | Mar Jul 01, 2008 8:02 am | |
CAUSE: The memory in the 25 mode is corrupted. SOLUTION: Set address 4 in the 25 mode to 0 to disable the memory card recognition. Check all 25 mode address settings. If all addresses are set to F and the control board is newly replaced, reinitialize the machine by first setting address 00 to 1 in the 25 mode. Then perform the reinitialization by using the 47 mode output code 92, and pressing the start print button. Reprogram all adjustment modes Si tienes alguna duda me comentas. Saludos y suerte!!! |
