Sharp AR205 toner compatible
comentario del autor Lun May 14, 2007 7:20 pm
Mi duda es que si es compatible el toner de la Xerox XD100 con la Sharp AR205.
Gracias.
Aliadodelpunk
asistió a la solución Lun May 14, 2007 7:54 pm
Hola :
AR 205 =Lanier Worldwide 5220 Sharp AL1600, Sharp AL1610, Sharp AL1620, Sharp AL1621, Sharp AL1640, Sharp AL1650, Sharp AL1670, Sharp AR160, Sharp AR160CL, Sharp AR160E, Sharp AR160EL, Sharp AR160L, Sharp AR161, Sharp AR161CL, Sharp AR161EL, Sharp AR161J, Sharp AR161L, Sharp AR200, Sharp AR200J, Sharp AR200L, Sharp AR200S, Sharp AR200SE, Sharp AR200SJ, Sharp AR205, Sharp AR205J, Sharp DM2000, Sharp DM2005, Sharp DM2010, Sharp DM2015
XD 100 =WORKCENTRE XD 100 EU NA SA Triumph-Adler DC 100 -A EU
. Triumph-Adler DC 120 -A
. Triumph-Adler DC 120 -B
. Triumph-Adler DC 100 -B
. Olivetti Lexikon COPIA 9910 -A
. Olivetti Lexikon COPIA 9910 -B
. Olivetti Lexikon COPIA 9912 -B
. Olivetti Lexikon COPIA 9912 -A
. Xerox WORKCENTRE XD 102
. Xerox WORKCENTRE XD 120 F
. Xerox WORKCENTRE XD 105 F
. Xerox WORKCENTRE XD 104
. Xerox WORKCENTRE XD 103 F
. Sharp AL 1200
. Sharp AL 1251
. Sharp AL 1001
. Sharp AL 1020
. Sharp AL 1000
. Sharp AL 1041
. Sharp AL 1220
. Sharp AL 1010
. Sharp AL 1250
. Toshiba E-STUDIO 12
Luis
P.R. Very Happy
LACTECH
asistió a la solución Lun May 14, 2007 7:55 pm
hola aca tienes los compatibles:
TONER - Compatible - Refill - 600 Gram Bottle - Our refill toner is intended for use by professional refillers only.
YOUR PRICE:
$19.95
FOR USE IN MODELS: Sharp AL1600, Sharp AL1610, Sharp AL1620, Sharp AL1621, Sharp AL1640, Sharp AL1650, Sharp AL1670, Sharp AR160, Sharp AR160CL, Sharp AR160E, Sharp AR160EL, Sharp AR160L, Sharp AR161, Sharp AR161CL, Sharp AR161EL, Sharp AR161J, Sharp AR161L, Sharp AR200, Sharp AR200J, Sharp AR200L, Sharp AR200S, Sharp AR200SE, Sharp AR200SJ, Sharp AR205, Sharp AR205J, Sharp DM2000, Sharp DM2005, Sharp DM2010, Sharp DM2015
OEM PART #: N/A
si le puedes colocar toner de al 1000 ,el cartucho (carcaza) es diferente pero el toner es igual.
saludos y suerte
carlos marenco
comentario del autor Lun May 14, 2007 9:26 pm
Gracias por la ayuda.
Y además quisiera saber como hacer para realizar el autotoner en esta máquina.
Gracias por su colaboración.
Valora las ayudas que recibes,seleccionando primero la opción y luego valorar
Aliadodelpunk
comentario Lun May 14, 2007 10:43 pm
Saludos amigo:
Como ya sabes, gracias a la ayuda brindada por los colegas puedes usar para recarga el toner de las XD100 o SHARP serie AL ya que son totalmente compatibles pero contienen menos cantidad.
Ese modelo no tiene ningun codigo de calibracion de Toner o Revelador como si tienen otros modelos SHARP solo se instala la caja de toner/revelador operativa y la maquina le hace un autoreconocimiento y se autocalibra sola.
Espero que ahora tus dudas esten aclaradas.
saludos cordiales
ricardosharp
ricardosharp
comentario del autor Mie May 16, 2007 3:03 pm
Otra vez amigos, necesitando su ayuda.
Ahora quisiera saber como ajustar el modo automático (darle más luz) a la AR5015.
Gracias
Aliadodelpunk
asistió a la solución Mie May 16, 2007 4:40 pm
hola,para entrar :
#→INTERRUP→"C"→INTERRUP→CODIGO PRINCIPAL→START→CODIGO SECUNDARIO→START→OFF/ON
46/18=AJUSTE DE CONTRASTE DE LA IMAGEN
46/19=CONFIGURACION DEL MODO DE EXPOSICION
te recomiendo no mover estos valores,si le falta nitidez en la copia ,revisa el revelador,limpieza de la optica y laser ,mantenimiento general ,etc
espera otras opiniones..
saludos y suerte
carlos marenco
