ricoh aficio 1085
comentario del autor Mie Jul 02, 2008 5:34 pm
por nada borra el botle tonner full
sa_derecho
sin valorar Mie Jul 02, 2008 5:46 pm
hola sa_derecho:
Se supone que el error que te sale es el bote de toner residual que hay debajo de las dos botellas de toner, no te estarás confundiendo con la botella de toner aspirado que está a la derecha de la maquina?
Brownerman
Entafe
sin valorar Mie Jul 02, 2008 6:30 pm
si no es lo que el collega ha mencionado le envio otros puntos a verificar
WASTE TONER FULL DISPLAY [false waste toner full display] - adjust sensor bracket closer to actuator
WASTE TONER FULL DISPLAY [false waste toner full display] - burr on coil shaft causing toner backup
WASTE TONER FULL DISPLAY [false waste toner full display] - check SP 29 71 to determine which bottle is full - left toner collection bottle or right toner collection bottle(A294II only)
WASTE TONER FULL DISPLAY [false waste toner full display] - check or reset 2972 or 2973 to 0 - 2972 (sucked toner bottle op. time), 2973 (suction motor op. time) (enhanced,1085/1105 only)
WASTE TONER FULL DISPLAY [false waste toner full display] - check seal on toner bank slider, if damaged, toner will leak onto toner overflow sensor - slider #A2943290
WASTE TONER FULL DISPLAY [false waste toner full display] - clean or replace the toner collection coil
WASTE TONER FULL DISPLAY [false waste toner full display] - clean or replace waste toner coil torque limiter
WASTE TONER FULL DISPLAY [false waste toner full display] - refer to TSB A294 49 - toner bottle full condition cannot be reset
WASTE TONER FULL DISPLAY [false waste toner full display] - replace the toner collection motor
WASTE TONER FULL DISPLAY [false waste toner full display] - toner bottle spill
WASTE TONER FULL DISPLAY [false waste toner full display] - toner collection bottle seal blocking coil
WASTE TONER FULL DISPLAY [false waste toner full display] - toner collection bottle sensor
WASTE TONER FULL DISPLAY [toner collection bottle is filled to fast] - charge bias grid power pack
WASTE TONER FULL DISPLAY [waste toner full display] - adjust sensor bracket closer to actuator
WASTE TONER FULL DISPLAY [waste toner full display] - advised customer to have tech come out to empty bottle.
WASTE TONER FULL DISPLAY [waste toner full display] - check or set SP 2971 1, 2 and 3 to 0
WASTE TONER FULL DISPLAY [waste toner full display] - clean or replace the toner collection coil
suerte
aficioman
