| comentario del autor | Jue Jul 28, 2005 4:51 pm | |
| comentario | Jue Jul 28, 2005 6:30 pm | |
C0000 Main drive problem C0010 Main drive speed problem. Too fast or too slow C0011 Drum motor speed problem. Too fast or too slow C004C Fan motor problem C004E Power supply fan problem C0070 Toner motor drive problem C0071 Toner motor speed problem. Too fast or too slow C0400 Exposure lamp does not turn on or AE sensor problem C0500, C0510 Low fuser temp during warm up C0520 High fuser temperature C0600 Scan motor drive problem C0610 Lens motor drive problem C0620 Mirror motor drive problem C0900 3rd drawer lift problem C0901-C0903 3rd drawer lower sensor C0904 3rd drawer lift motor C0950, C0951 4th drawer lift sensor C0952 4th drawer lower sensor C0953 4th drawer lower sensor C0990 Main tray up problem C0991, C0992 Main tray down problem C0993 Main tray up problem C0994 Elevator motor problem C0996 3rd drawer lock release problem C0998 Shift transfer problem C0998 Tray shift problem C0999 Tray shift return problem C099A Shift home problem C099b Shift transfer problem C099c Shift drive motor C099E, C099F Shift gate problem C0b10, C0b11 Paper clamp motor C0b31 Paper aligning motor C0b50 Stapler motor C0b51 Stapler problem C0b52 Stapler sensor C0b60 Sorter bin motor C0b61 Sorter bin movement C0b62 Sorter bin movement C0d00 Duplex rail sensor problems C0d20 Duplex trail gate home sensor C0d50 Duplex drive motor problem C0d51 Duplex drive motor speed. Too slow or too fast C0F10 Auto exposure sensor problem C0F30 Auto toner density sensor problem C0F79 Paper empty sensor problem C4100 Exposure lamp stays on C0b30 Paper aligning motor C0b63, C0b64 Sorter bin movement Minolta 2050 Code Description C000 Drive problem C0010 Drive motor at wrong speed C0040/1 Fan motor C004A Exposure fan problem C004b Exposure fan turning at wrong speed C0071 Main toner motor at wrong speed C0072 Sub toner hopper motor C0200 Corona problem C03-- Main board or harness C0400 Exposure lamp C0410 Exposure lamp timing wrong C0500 Fuser problem. Warm-up incomplete C0510 Low fuser temperature C0520 High fuser temperature C0522 Fuser front rear thermistor C0600 Scan drive problem C0601 Scan board C0610 Lens drive problem C0620 4th & 5th mirror failure C0650 Scan detect problem C0660 Scan load problem C06F0toC06F7 Scan interface problem C070 Main toner hopper motor C0900 3rd drawer lift problem C0904 3rd drawer lift motor C0950 4th drawer lift problem C0954 4th drawer lift motor C0990-996 Main drawer problem C0998,999,99A,99b,99Cd Shift drawer problem C0b0- Sorter drive problem C0b1- Clamp problem C0b3- Sorter aligning motor C0b5- Stapler problem C0b6- Sorter bin problem C0b7- Punch problem C0d00 Duplex front rear C0d20 Duplex gate home sensor problem C0d50 Duplex motor not turning C0d51 Duplex motor at wrong speed C0E00 Main erase problem C0E01 Main erase lamp at wrong time C0E20 Image erase problem C0F02 Original size detect board problem C0F10 Auto exposure board problem C0F20-C0F23 Auto image density control sensor C0F30, C0F31 Auto toner sensor problem C0F79 Paper empty board problem C0FE/F Original size sensor problem estas maquinas creo que tienen un switch que ademas de servicio resetea los codigos de error asi que busca en la tarjeta nosin antes revisar si es codigo de fusion lampara termostato termistor etc ok suerte y dime ya me agregate a tu listado de contactos del mesenger nilsonmorales arroba hot mail punto com |
