NUEVO BLOG YoReparo!
| comentario del autor | Lun Dic 13, 2004 10:32 pm | |
| comentario | Mar Dic 14, 2004 7:32 pm | |
| sin valorar | Vie Dic 31, 2004 6:28 am | |
U-2 Lamp Carriage / Half-Rate Carriage Drive Problems U-3 Lens & Mirror Drive Problem U-4 Fuser Problem... Check out the Heat Lamp, reset the Thermal Fuse if needed, & make sure the Thermistor is in position & ok U-6 Main Board Battery Low: Check voltage between TP1 & TP2 on the Main Board... if the voltage is below 2 VDC, replace the batteries. U-8 Exposure Lamp Control Circuit Problem : Could be the Exposure Lamp or exposure thermal fuse... or the exposure sensor isn't seeing the lamp come on. The sensor looks through the mirrors at a reference strip on the flip side of the lead edge guide to the left of the platen glass. Make sure the mirrors, sensor, & reference strip are clean & in place. Diagnostics: To enter diagnostics: Turn on the copier while holding the '0' button... all display panel indicators will light. To enter a code: Enter the code followed by the Start button. To exit diagnostics: Turn power off. |
| comentario del autor | Mie Ene 05, 2005 11:49 pm | |
