www.YoReparo.com
Codigo SC746 en una Ricoh 8680
comentario del autor Lun Mar 14, 2005 3:03 pm
Empezo a tirar este código y se bloqueo el equipo. ¿Alguna idea? Gracias a todos.
mipenca
asistió a la solución Lun Mar 28, 2005 3:17 am
Aca te mando una copia del manual con respecto a la falla espero que te se util
SC746 - Sorter Connection Failure
Definition:
The copier main PCB cannot communicate with the sorter main PCB, or the
sorter main PCB cannot communicate with the second sorter main PCB.
This SC is always displayed as a system error condition and can be reset as
necessary. The SC counter for this code however, does increment.
Points to check:
· Connectors between the 1st and 2nd sorters
· 2nd sorter interface PCB
· 2nd sorter power line
· Sorter main PCBs
· FUSE1 on the sorter power supply PCB
jorge4172
