| comentario del autor | Lun Oct 02, 2006 7:57 pm | |
| sin valorar | Lun Oct 02, 2006 8:57 pm | |
SERVICE MODE OPEN FRONT DOOR AND CHEAT DOOR SWITCH USING AN ALLAN KEY INSET IT THROUGT THE HOLE IN THE INNER FRONT PANEL AND ACTUATE SERVICE MODE 850A 2MMMM ALLAN IS A TIGHT FIT A STRAIGTHENED PAPER CLIP WORKS BETTER DISPLAY WILL SHOW 1 THEN PRESS THE MODE YOU WANT TO USE THEN PRESS OK DISPLAY SHOW 3 DIGITS 619 OK MODO 5 Y 619 |
