ayuda codigo h2 xerox xc1020
comentario del autor Mie Dic 15, 2004 1:07 pm
hola coleguitas si me puede
n echar la mano para borrar el error h2 en xerox xc 1020 mucho agradecere
fernando
copyczm
fernandomoraortiz
sin valorar Vie Dic 31, 2004 6:25 am
STATUS CODES:
A1 SDF Document Jam
A2 SDF Document Jam
CH Toner Cartridge not present or not seated properly
H2 Thermistor Open
H3* High fuser temperature
H4* Low fuser temperature
L1 Scanner carriage did not leave home position on power up or upon pressing start
L3 Scanner carriage did not return to home position after copy cycle
L4 Main motor problem
L5 Lens did not leave home after power up or upon selecting reduction or enlargement
P Paper feed problem (Paper didn’t reach the paper feed sensor in time)
U2** Memory failure
U5 SDF high temperature (or SDF thermistor failure)
DIAGNOSTICS:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
HECTORRI
