| comentario del autor | Mar Jul 01, 2008 9:41 pm | |
Alguna sugerencia. saludos |
| asistió a la solución | Mar Jul 01, 2008 9:58 pm | |
podria ser power supply en el caso que se apage y se prenda seria lo siguiente ha verificar [machine shuts off then back on] - Transfer unit harness stuck in duplex tray frame connector - re- route harness [machine shuts off then back on] - check ribbon cable for print controller-shorted to frame [machine shuts off then back on] - fuse 1 13 [machine shuts off then back on] - paper stuck inside paper tray conector - check behind trays for paper in any of the tray connectors [machine shuts off then back on] - reload with latest firmware [now loading displayed, machine shuts off then back on] - check tandem tray for pinched wire-CN2 7 2 on paper feed control PCB [now loading displayed, machine shuts off then back on] - paper stuck in a paper tray connector [now loading displayed, machine shuts off then back on] - replace SBI C U [now loading displayed, machine shuts off then back on] - replace finisher main board [now loading displayed, machine shuts off then back on] - replace power supply PCB [now loading displayed, machine shuts off then back on] - upgrade firmware fuse 1 13, reload with latest firmware, paper stuck inside paper tray conector - check behind trays for paper in any of the tray connectors |
| asistió a la solución | Dom Jul 06, 2008 9:47 pm | |
Revisa el sistema de pote de recogida de toner usado , suele titilar y pedir vaciar el pote y a la vez apaga el equipo, otra cosa que me sucedio en varias maquinas es que pide titlando agregar broches al sorter y lo tiene , esto tambien me apaga la maquina. Saludos Luis |
| comentario del autor | Dom Jul 06, 2008 9:56 pm | |
| sin valorar | Dom Jul 06, 2008 10:20 pm | |
Saludos Luis |
