www.YoReparo.com
Memoria USB No sirve
comentario del autor Lun Jul 10, 2006 10:37 pm
Amigos que tal esta vez tengo un problema con una memoria USB Kingston Data travel 2.0 es reconosida en los equipos normalmente peo lo que pasa es que aparece como si no tuviera disco? intente formatearla bajo DOS y no deja sale error . corri un soft HP para particionar el Usb y tampoco que hago!!! intente correrle el FAt ecover en fi ya no se que hacer espero ayuda suya..
saludos...
y gracias por su time...
johanveri
sin valorar Lun Jul 10, 2006 10:45 pm
Me parece raro.... pero nos podrias dar algunos datos más.....
Bajo que sistema opertivo la querés hacer funcionar.... Question
CORO89
asistió a la solución Mar Jul 11, 2006 6:27 am
Haber si te sirve esto:
Cita:
In certain conditions which are difficult to reproduce, USB Flash drive may suddenly stop working properly and begin to present itself to Windows XP as "Security device", prompting for drivers which are not normally required. It is possible to restore drive's functionality, but unfortunately any existing information on it will be lost.
Here is the recovery procedure:
Download Canyon EZ Recovery utility (http://www.canyon-tech.com/files/Canyon/USB-Flash/Plastic/EZ_Recover_CANYON_2570.zip) and USB Flash Tools (http://www.canyon-tech.com/files/Canyon/USB-Flash/Plastic/PL15UtilV10030.exe)
Install both packages, reboot and run EZ Recovery tool
Plug USB flash device into USB port and press Recover button
Wait until process completes (it is possible that error message will be displayed at the end, ignore it and continue)
Unplug the device and plug it back again as prompted
Start USB Flash Tools, leave password field empty and press OK
Press "Format" button and wait until process completes
Exit from service utility and use your USB Flash drive normally
Ademas buscate este software:
memory stick data recovery demo
Tambien es conocido como: Data doctor Recovery - Pen drive
Fabricado por: Pro Data Doctor
Saludos Wink
carlitoszihua
sin valorar Mar Jul 11, 2006 4:42 pm
carlitoszihua escribió:Haber si te sirve esto:
Cita:
Saludos Wink
Esa es buena, no la sabía.... Rolling Eyes
CORO89
sin valorar Sab Nov 17, 2007 3:02 pm
Me paso exactamente igual con un kingston data traveler de 1gb.
Los sistemas operativos lo reconocian pero no me dejaba ver dato alguno, ademas que aparecia como CERO (0) en todos los sectores.
Conseguite en www.taringa.net este software:
hdd low level format tools
con esto lo que haces es, una ves instalado el programa, debes conectar la memoria usb en los puertos traseros (esto es indiferente pero es mejor por atras jeje..)
elijes la unidad.
luego en la solapa dos (low format) le haces clic en siguiente y te va a formatear la memoria.
Al terminar, vas a mi pc y haces clic con boton derecho en la memoria usb.
elijes format
Tipo Fat pero NUNCA formato rapido... solo normal...
una ves concluido ya estara listo para TODO!
Espero les sirva!
luisitox
sin valorar Mar May 20, 2008 2:52 am
no se si sea el mismo problema, pero,,,
tengo xp pro sp2, maquina pentium D,, 512ram,,, mcafee 2008,,,
entonces, meto la memoria,, y aparece el icono verde en la barra de inicio,, la flecha,,, pero! no aparece la unidad en mi pc,, ni en el explorador ni desde msDOS,,,,,,, no la puedo ver,, pero si la puedo kitar de forma segura,,, ya intente en otras maquinas,, pero como son de caracteristicas en hardware y software muy simiares, pues me paso lo mimos,, que aparece el icono verde, pero no aaparece la unidad....
solo en una lap,, xp pro sp2,, nis 2008 si la lee bien,,,
ahora no creo que sea problema de controlador usb,,, puesto que meto otra memoria sanddisk,, y sin problemas, pero la que uso es la data traveler de kingston..
java985
