| comentario del autor | Jue Dic 30, 2004 1:17 am | |
gracias |
| comentario | Jue Dic 30, 2004 1:44 am | |
o si no es onboard, proba a ver si esta bien puesta en el mother.. quizas esta medio floja... Proba de ponerle otra placa de video que seguro que te anda. Saludos |
| comentario del autor | Jue Dic 30, 2004 2:00 am | |
gracias |
| comentario | Jue Dic 30, 2004 1:16 pm | |
Exitos. |
| comentario del autor | Jue Dic 30, 2004 2:52 pm | |
gracias por las respuestas a todos |
| comentario | Jue Dic 30, 2004 7:29 pm | |
A saber: Probaste la fuente. Si esta funcionara mal los síntomas podrían ser los mismos que mencionás. Seguramente tu mother es un m810 de Pcchips. Es frecuente en estos mothers que algunos de los bancos de memoria comiencen, con el tiempo a tirar errores. Sacale la memoria y cambiala de banco, si tenés dos, andá probándolas de a una. Suerte! |
| comentario | Jue Dic 30, 2004 9:07 pm | |
| comentario | Vie Dic 31, 2004 12:38 am | |
Suerte. |
| comentario del autor | Vie Dic 31, 2004 1:20 am | |
Gracias a todos |
| comentario | Vie Dic 31, 2004 2:39 am | |
| comentario | Vie Dic 31, 2004 12:05 pm | |
This mainboard has a slot-1 processor socket for an Intel processor cartridge, and it also has a socket-370 for an Intel PPGA (Plastic Pin Grid Array) Celeron or FCPGA Pentium III processor. You can install either one of these processors according to the power and performance requirements that you need from your system. Note that you cannot install two processors on this mainboard. Slot-1 processors include the SEPP (Single Edge Processor Package) Celeron, the Pentium-II, and the Pentium-III. The mainboard supports a system bus of 66 MHz or 100 MHz. The mainboard uses the Xcel 2000 chipset which provides CPU Plug & Play through firmware. The mainboard is highly integrated and includes a built-in 64-bit AGP Graphics Accelerator, a built-in PCI 3D Sound System, and a built-in 10BaseT/100BaseTX Network Adapter. A V.90 Fax/modem DAA module is also shipped with the mainboard. In addition, it has a full set of AT I/O Ports including a serial port, a PS/2 mouse port, a parallel port and two USB ports. This mainboard has all the features you need to develop a powerful multimedia workstation that is network ready, and has built-in communications. The board is Baby-AT sized and has power connectors for ATX and AT power supply units and it can be installed in AT system case. Key Features This key features of this mainboard include: Slot-1 Processor Support ¨ Pentium-III support for 450 MHz and 800 MHz clock rates ¨ Pentium-II support for 233 MHz to 450 MHz clock rates ¨ SEPP Celeron support for 266 MHz to 433 MHz clock rates ¨ Support for 66 MHz and 100 MHz FSB (Front Side Bus) ¨ All processors configured by CPU Plug & Play Socket-370 Processor Support ¨ Supports PPGA Celeron CPUs which provide Pentium-II performance with integrated level 1 and level 2 cache ¨ FCPGA Pentium III CPUs are supported ¨ Supports 66 MHz and 100 MHz front side system bus ¨ All Celerons are automatically configured using firmware Memory Support ¨ Three DIMM slots for SDRAM 168-pin memory modules ¨ Support for 66 MHz & 100 MHz memory bus ¨ Maximum installed memory can be 3 x 256 MB = 768 MB Expansion Slots ¨ One 32-bit PCI slot ¨ One 8/16-bit ISA slot Onboard IDE channels ¨ Primary and Secondary PCI IDE channels ¨ Support for PIO (programmable input/output) modes ¨ Support for Bus mastering and UltraDMA 33/66 modes Power Supply and Power Management ¨ Dual connector for either an AT or ATX power supply ¨ Support for Green PC standard, suspend switch, keyboard power on/off Si no interpreto mal, este mother no llega a soportar un duron 1200... |
| comentario del autor | Vie Dic 31, 2004 1:06 pm | |
de memoria, es que estoy con 3 maquinas a la vez, disculpen |
| comentario | Lun Ene 03, 2005 11:51 am | |
