| comentario del autor | Jue Abr 07, 2005 4:37 pm | |
por lo que lei no se pueden resetear pero si bloquear. Lo que no se como. Y no encontre una repuesta a esto si alguien me pude ayudar. gracias. |
| asistió a la solución | Jue Abr 28, 2005 3:16 pm | |
| solución | Sab Abr 30, 2005 8:33 am | |
(Los pasos estan referidos a los comandos del programa ese) 1) Move cartridge to exchange position using functions build in this utility. 2) Remove cartridge 3) You will see small chip with few contacts. Configuration of contacts is shown below : 1 2 3 4 5 6 7 4) Use very thin adhesive tape to cover only first contact. 5) Insert cartridge back. Also note, what You can exchange CSIC chips in color and black cartridges. 6) Move head to parking position and turn printer off. 7) You can also try to use reset printer counters function here. 9) If cartridge didn't became full (old values or 1/4) try turn off printer and repeat sequence from step 7). 10) Use normal cartridge exchange build in Epson drivers (or by printer buttons) to remove adhesive tape. |
