| comentario del autor | Sab May 10, 2008 9:02 am |
ubuntu no meda la persion para montar el disco ?
me aparece el error siguiente $LogFile indicates unclean shutdown (0, 0) Failed to mount '/dev/sda5': Opération non supportée Mount is denied because NTFS is marked to be in use. Choose one action: Choice 1: If you have Windows then disconnect the external devices by clicking on the 'Safely Remove Hardware' icon in the Windows taskbar then shutdown Windows cleanly. Choice 2: If you don't have Windows then you can use the 'force' option for your own responsibility. For example type on the command line: mount -t ntfs-3g /dev/sda5 /media/sda5 -o force Or add the option to the relevant row in the /etc/fstab file: |
| sin valorar | Sab May 10, 2008 3:07 pm |
Pero tenés instalado ntfs-3g?
Código:
Código:
