| comentario del autor | Sab May 17, 2008 1:14 pm |
hola amigos he ekrido instalar lotus en i fedora 9 pero me bota este error espero que me puedan ayudar
gracias tzmappings: Illegal format at near line 11. Locking assertion failure. Backtrace: #0 /usr/lib/libxcb-xlib.so.0 [0x88c767] #1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_unlock+0x31) [0x88c831] #2 /usr/lib/libX11.so.6(_XReply+0x244) [0xe6df64] #3 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/xawt/libmawt.so(XineramaQueryScreens+0x8c) [0xca927c] #4 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/xawt/libmawt.so(xineramaInit+0x5a) [0xc947f6] #5 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/xawt/libmawt.so(awt_init_Display+0xf9) [0xc94955] #6 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/xawt/libmawt.so(Java_sun_awt_X11GraphicsEnvironment_initDisplay+0x1e) [0xc94b86] #7 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9vm23.so [0x155d52] #8 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libjclscar_23.so(java_lang_J9VMInternals_initializeImpl+0x7e) [0x5b53da] #9 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libjclscar_23.so(java_lang_Class_forNameImpl+0x2be) [0x5bd80a] #10 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libjclscar_23.so(java_lang_J9VMInternals_initializeImpl+0x7e) [0x5b53da] #11 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libjclscar_23.so(java_lang_Class_forNameImpl+0x2be) [0x5bd80a] #12 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9vm23.so [0x180064] #13 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9prt23.so [0x1ab168] #14 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9vm23.so [0x17eb29] #15 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9thr23.so [0x13d117] #16 /lib/libpthread.so.0 [0xa6232f] #17 /lib/libc.so.6(clone+0x5e) [0x99d27e] Locking assertion failure. Backtrace: #0 /usr/lib/libxcb-xlib.so.0 [0x88c767] #1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_lock+0x2e) [0x88c90e] #2 /usr/lib/libX11.so.6 [0xe6d109] #3 /usr/lib/libX11.so.6(XGetVisualInfo+0x26) [0xe631f6] #4 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/xawt/libmawt.so [0xc93be4] #5 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/xawt/libmawt.so [0xc93ddd] #6 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/xawt/libmawt.so(awt_init_Display+0x1a5) [0xc94a01] #7 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/xawt/libmawt.so(Java_sun_awt_X11GraphicsEnvironment_initDisplay+0x1e) [0xc94b86] #8 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9vm23.so [0x155d52] #9 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libjclscar_23.so(java_lang_J9VMInternals_initializeImpl+0x7e) [0x5b53da] #10 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libjclscar_23.so(java_lang_Class_forNameImpl+0x2be) [0x5bd80a] #11 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libjclscar_23.so(java_lang_J9VMInternals_initializeImpl+0x7e) [0x5b53da] #12 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libjclscar_23.so(java_lang_Class_forNameImpl+0x2be) [0x5bd80a] #13 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9vm23.so [0x180064] #14 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9prt23.so [0x1ab168] #15 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9vm23.so [0x17eb29] #16 /tmp/istemp15136138121015/_bundledJRE_/jre/bin/libj9thr23.so [0x13d117] #17 /lib/libpthread.so.0 [0xa6232f] #18 /lib/libc.so.6(clone+0x5e) [0x99d27e] The installer is unable to run in graphical mode. Try running the installer with the -console or-silent flag. |
| sin valorar | Vie May 23, 2008 12:57 am |
¿tienes java instalado?, ¿que te marca cuando lo corres en consola?
