NUEVO BLOG YoReparo!
| comentario del autor | Vie Oct 26, 2007 3:23 pm | |
Saludos |
| solución | Sab Oct 27, 2007 9:35 am | |
// Software for the "No-Parts Pic Programmer" // Inspired by David Tait's TOPIC; compatible therewith. // This is Microsoft C. // Be sure to compile for 8088 (not 286 or 386) for maximum portability. // Command line arguments: // None. // Environment variable: // PPLPT=n where n=1, 2, or 3 specifies which LPT port to use. #define BANNER "NOPPP - \"No-Parts\" PIC Programmer" #include <stdio.h> #include <conio.h> #include <stdlib.h> #include <ctype.h> #include <string.h> typedef unsigned int word; typedef unsigned char byte, bit; // ********************************************************************* // GLOBAL STATUS VARIABLES // ********************************************************************* int LPT = 0, // which LPT port we're using (1..3) PORT = 0; // its port address #define PIC16C84 1 #define PIC16F84 2 #define PIC16F83 3 int DEVICE = 0; // which PIC we're programming #define PROGRAM 1 #define VERIFY 0 // desired action in main programming loop char FNAME[255]; // name of file currently loaded char CHOICE = 0; // user's most recent menu choice // ********************************************************************* // I/O UTILITIES // ********************************************************************* #define KBUFSIZE 256 char buf[KBUFSIZE]; // keyboard input buffer char* cleanctrl(char *s) { // truncates string at first ctrl char, int i=0; // cleaning up ^M or ^J left behind by fgets while (s[i] >= ' ') i++; s[i] = 0; return s; } char* getstring() { // read string fgets(buf,KBUFSIZE-1,stdin); cleanctrl(buf); return buf; } int getint() { return atoi(getstring()); }; // read integer char getchoice(char *s) { // read menu choice // prints prompt, then reads letters, uppercasing, // until a letter that is in s is found printf("\n\nYour choice (%s): ",s); do { CHOICE = _getch(); CHOICE = toupper(CHOICE); // toupper evals arg twice, so arg can't be _getch() } while ((CHOICE == ',') || (strchr(s,CHOICE) == NULL)); printf("%c\n",CHOICE); return CHOICE; } void clearscreen() { __asm { mov ax,0f00h int 010h mov ah,0 int 010h } } void waitkey() { while (_kbhit()) { _getch(); }; puts("\nPress space bar to continue..."); _getch(); while (_kbhit()) { _getch(); }; } void errmsg(char *s) { puts(s); waitkey(); } // ********************************************************************* // TIMING // ********************************************************************* #define IODELAY (_inp(0x61)) // allow time for timer to respond void delay(int k) { // Delay at least k microseconds, possibly a good bit more. // k must be less than 27304. // Minimum delay on a 25-MHz 386 is about 100 microseconds; // on a 133-MHz Pentium, about 18 microseconds. // Uses system timer 2. // When running in a DOS box under OS/2, set HW_TIMER ON in DOS settings. unsigned int w; unsigned char lo,hi; _outp(0x61, (_inp(0x61) & 0xFD) | 1); // spkr off, tmr 2 gate on w = (unsigned int)(k*1.2); _outp(0x43, 0xB0); // tmr 2 mode 0 2-byte load IODELAY; _outp(0x42, (unsigned char)w); // low byte IODELAY; _outp(0x42, (unsigned char)(w>> IODELAY; do { _outp(0x43,0x80); // latch timer count IODELAY; lo = _inp(0x42); // discard low byte IODELAY; hi = _inp(0x42); // get high byte IODELAY; } while ((hi & 0x80) == 0); // wait for a 1 there, signifying rollover return; } // ********************************************************************* // PARALLEL PORT HARDWARE INTERFACE // ********************************************************************* // Uses two-wire serial data communication through printer port. // Pin 1, STROBE, is serial clock; // Pin 14, AUTOFD, is serial data out to PIC; // Pin 11, BUSY, is serial data in from PIC; // Pin 17, SLCTIN, is low when writing, high to provide pull-up when reading; // Pin 2, D0, is lowered to apply Vpp. // SLCTIN and BUSY are tied together for pull-up and for hardware detection. // (In current versions this is done through diodes or gates.) // SLCTIN is an open-collector output with pull-up. // If it is pulled down, some printer ports will latch it down. // Accordingly, it and all the other control bits are asserted // every time they are needed. byte BITS = 0x0F; word portaddr(int n) { // base address of port LPTn return(*(word far *)(0x00000408+2*n-2)); } // Procedures to set and clear the data lines void datawritable() { // SLCTIN, AUTOFD down BITS |= 0x0A; _outp(PORT+2,BITS); } void datareadable() { // SLCTIN, AUTOFD up BITS &= ~0x0A; _outp(PORT+2,BITS); } void datadown() { BITS |= 0x02; _outp(PORT+2, BITS); } // AUTOFD down void dataup() { BITS &= ~0x02; _outp(PORT+2, BITS); } // AUTOFD up void clockdown() { BITS |= 0x01; _outp(PORT+2, BITS); } // STROBE down void clockup() { BITS &= ~0x01; _outp(PORT+2, BITS); } // STROBE up void vppon() { BITS &= ~0x04; _outp(PORT+2, BITS); // INIT down, D0 down _outp(PORT, 0 ); } void vppoff() { BITS |= 0x04; _outp(PORT+2, BITS); // INIT up, D0 up _outp(PORT, 1 ); } bit datain() { return(((~(byte)_inp(PORT+1)) & 0x80) >> 7); } void allpinslow() { vppoff(); //datawritable(); //datadown(); //clockdown(); BITS = 0x0F; _outp(PORT+2, BITS); } bit detecthardware() { // True if BUSY and SLCTIN are tied together. datawritable(); // SLCTIN down dataup(); // AUTOFD up delay(10); if (datain() == 1) return(0); datareadable(); // SLCTIN up dataup(); // AUTOFD up delay(10); if (datain() == 0) return(0); return(1); } // ********************************************************************* // PIC COMMUNICATION ROUTINES // ********************************************************************* void sendbit(bit b) { // Sends out 1 bit to PIC if (b) dataup(); else datadown(); clockup(); delay(1); // tset1 clockdown(); // data is clocked into PIC on this edge delay(1); // thld1 datadown(); // idle with data line low } bit recvbit() { // Receives a bit from PIC bit b; clockup(); delay(1); // tdly3 clockdown(); // data is ready just before this b = datain(); delay(1); // thld1 return b; } void sendcmd(byte b) { // Sends 6-bit command from bottom of b int i; datawritable(); delay(2); // thld0 for (i=6; i>0; i--) { sendbit((bit)(b & 1)); b = b >> 1; } delay(2); // tdly2 } void senddata(word w) { // Sends 14-bit word from bottom of w int i; datawritable(); delay(2); // thld0 sendbit(0); // one garbage bit for (i=14; i>0; i--) { sendbit((bit)(w & 1)); // 14 data bits w = w >> 1; } sendbit(0); // one garbage bit delay(2); // tdly2 } word recvdata() { // Receives 14-bit word, lsb first int i; bit b; word w = 0; datareadable(); // SLCTIN up for pull-up delay(2); // thld0 recvbit(); // one garbage bit for (i=0; i<14; i++) { b = recvbit(); w = w | ((word)b << i); // 14 data bits } recvbit(); // another garbage bit; delay(2); // tdly2 return w; } // ********************************************************************* // PIC PROGRAMMING ALGORITHMS // ********************************************************************* // PIC MEMORY MAP // The PIC16F84 has four programmable memory areas // (plus data RAM, which is not programmable). // Config memory is only 1 byte, but is treated like the others. #define PBASE 0 // Base address of each memory #define IBASE 0x2000 #define CBASE 0x2007 #define DBASE 0x2100 #define PSIZEMAX 1024 // Max size of each memory #define ISIZEMAX 4 #define CSIZEMAX 1 #define DSIZEMAX 64 word PSIZE = PSIZEMAX; // Actual size, can be set lower word ISIZE = ISIZEMAX; // for particular CPUs word CSIZE = CSIZEMAX; word DSIZE = DSIZEMAX; word PMEM[PSIZEMAX]; // Arrays representing the memories word IMEM[ISIZEMAX]; word CMEM[CSIZEMAX]; word DMEM[DSIZEMAX]; word PUSED = 0; // Number of valid words in array word CUSED = 0; word IUSED = 0; word DUSED = 0; #define PMASK 0x3fff // Which bits are used in each word word CMASK = 0x001f; // (CMASK depends on processor) #define IMASK 0x3fff #define DMASK 0x00ff word DEFAULTCONFIG = 0x1B; // Initialization for config word void cleararrays () { // Mark the memory arrays as empty PUSED = IUSED = CUSED = DUSED = 0; } bit stuffarray (word address, // Stuff data into a memory array. word array[], // Returns true if successful. word base, word size, word *used, word data[], int count) { int i; if (address-base+count-1 > size) { printf("Invalid address: %04XH\n",address+count-1); return 0; } for (i=0; i<count; i++) { array[i+address-base] = data[i]; if (*used < address-base+count) *used = address-base+count; } return 1; } // PIC PROGRAMMING COMMANDS byte LOADCONFIG = 0; byte LOADPROGRAM = 2; byte READPROGRAM = 4; byte INCREMENTADDRESS = 6; byte BEGINPROGRAMMING = 8; byte LOADDATA = 3; byte READDATA = 5; byte ERASEPROGRAM = 9; byte ERASEDATA = 11; // PROGRAMMING PROCEDURES void vppreset() { // reset PIC, apply Vpp vppoff(); datawritable(); datadown(); clockdown(); delay(25000); vppon(); delay(25000); } void progcycle(byte cmd, word arg) { // send a command and an argument, sendcmd(cmd); // then program EPROM accordingly senddata(arg); sendcmd(BEGINPROGRAMMING); delay(20000); // PIC errata sheet says 10ms is typical, not guaranteed } bit programall( // Program a memory from appropriate array. // Returns true if successful. int mode, // program or verify word mask, // to throw away irrelevant bits byte writecommand, // command to write this memory byte readcommand, // command to read this memory, word array[], // which memory array we're using word base, // its base address word used) { // number of valid words in array word i,w; switch(mode) { case PROGRAM: puts("programming..."); break; case VERIFY: puts("verifying..."); break; } for (i=0; i<used; i++) { printf("%04X\b\b\b\b",i+base); // display addr and backspace if (mode==PROGRAM) progcycle(writecommand,(array[i] & mask)); sendcmd(readcommand); w = (recvdata() & mask); if (w != (array[i] & mask)) { printf("Failed at %04X: Expecting %04X, found %04X.\n", i+base, (array[i] & mask), w); return 0; } sendcmd(INCREMENTADDRESS); } return 1; } // ********************************************************************* // HEX FILE LOADER // ********************************************************************* // This is for Intel INHX8M (8-bit merged) hex files only. // These files use two bytes for each word (low, then high). // All addresses are doubled, i.e., 0x2001 is encoded as 0x4002, // so that addresses increment at the same rate as the byte count. bit validhexline(char *s) { // Gross syntax and checksum check. byte cksum = 0; // For all HEX formats, not just 8M. int bytecount; int i, b; if (s[0] != ':') return(0); // Initial colon sscanf(s+1,"%2x",&bytecount); if (bytecount > 32) return(0); // Valid byte count cksum = bytecount; i = 3; bytecount = bytecount+3; while (bytecount>0) { bytecount--; sscanf(s+i,"%2x",&b); cksum = cksum+b; // Compute checksum i = i+2; } sscanf(s+i,"%2x",&b); cksum = -cksum; if (cksum == b) return 1; // Test checksum return 0; } void loadhexfile(FILE *f) { // Loads a hex file into memory arrays char s[256]; word i,lo,hi; word linetype = 0; // 0 for data, 1 for end of file word wordcount; // number of 16 bit words on this line word address; // address where they begin word data[8]; // 16 bytes = 8 words max. per line of hex cleararrays(); while((!feof(f)) && (linetype != 1)) { fgets(s,255,f); cleanctrl(s); if (!validhexline(s)) { // Syntax check s[40] = 0; // Truncate invalid line for display if (s[0] != ':') { printf("Invalid line (skipped): '%s'...\n",s); continue; } else { printf("Unable to decode line: '%s'...\n",s); goto bailout; } } sscanf(s+1,"%2x",&wordcount); // Parse the line - Intel Hex8M wordcount = wordcount/2; // (double bytes, addresses doubled) sscanf(s+3,"%4x",&address); address = address/2; sscanf(s+7,"%2x",&linetype); if (linetype==1) goto finished; for (i=0; i<wordcount; i++) { // Grab the data sscanf(s+(9+4*i),"%2x%2x",&lo,&hi); data[i] = (hi << } // Place in appropriate array if (address >= DBASE) { if (!stuffarray(address,DMEM,DBASE,DSIZE,&DUSED,data,wordcount)) goto bailout; } else if (address >= CBASE) { if (!stuffarray(address,CMEM,CBASE,CSIZE,&CUSED,data,wordcount)) goto bailout; } else if (address >= IBASE) { if (!stuffarray(address,IMEM,IBASE,ISIZE,&IUSED,data,wordcount)) goto bailout; } else { if (!stuffarray(address,PMEM,PBASE,PSIZE,&PUSED,data,wordcount)) goto bailout; } } // while finished: printf("Program memory loaded: %5d word(s)\n",PUSED); printf("Configuration loaded: %5d word(s)\n",CUSED); printf("ID memory loaded: %5d word(s)\n",IUSED); printf("Data memory loaded: %5d byte(s)\n",DUSED); return; bailout: cleararrays(); errmsg("Unable to load file."); FNAME[0] = 0; return; } // ********************************************************************* // USER INTERFACE // ********************************************************************* void banner() { clearscreen(); puts("---------------------------------"); puts(BANNER); puts("Michael A. Covington"); puts("Version of " __DATE__ " " __TIME__); puts("---------------------------------"); if (LPT > 0) printf("Using LPT%d on %03XH\n",LPT,PORT); puts("---------------------------------"); switch (DEVICE) { case PIC16C84: printf("PIC16C84"); break; case PIC16F84: printf("PIC16F84"); break; case PIC16F83: printf("PIC16F83"); break; default: printf(" "); } printf(" %s\n",FNAME); puts("---------------------------------\n"); } void selectport() { char c; c = (getenv("PPLPT"))[0]; if ((c >= '1') && (c <= '3')) { CHOICE = c; } else { banner(); printf("Which LPT port? "); getchoice("1,2,3"); puts("\nTo avoid having to make this selection"); puts("every time, you can add the command\n"); printf(" SET PPLPT=%c\n\n",CHOICE); puts("to your AUTOEXEC.BAT file."); errmsg(" "); } LPT = CHOICE - '0'; PORT = portaddr(LPT); banner(); puts("Apply power to programmer now.\n"); puts("If your programmer has adjustable Vcc,"); errmsg("set it to 5.0 volts."); if (!detecthardware()) { banner(); puts("Caution: Programmer hardware not found!\n\n"); puts("With some versions of the circuit and some"); puts("parallel ports, this may be normal.\n"); puts("If you are sure you have chosen the correct"); puts("parallel port, press space bar to proceed."); puts("To cancel program, press Ctrl-C."); errmsg(" "); } } void troubleshoot() { banner(); puts("Ensure programmer is powered up now,"); puts("with Vcc set to 5.0 V (if adjustable)"); puts("and no PIC in the socket."); errmsg(" "); allpinslow(); banner(); puts("TEST A\n"); puts("Connect negative voltmeter lead to pin 5"); puts("of PIC socket and check the following voltages:\n"); puts(" Socket pin 4 < 0.8 V"); puts(" Socket pin 12 < 0.8 V"); puts(" Socket pin 13 < 0.8 V"); puts(" Socket pin 14 4.75 to 5.25 V"); puts(" Junction of"); puts(" D1, D2, and R1 < 0.8 V"); errmsg(" "); vppon(); clockup(); dataup(); banner(); puts("TEST B\n"); puts("With negative voltmeter lead still"); puts("connected to pin 5 in the PIC socket,"); puts("check the following voltages:\n"); puts(" Socket pin 4 12.0 - 14.0 V"); puts(" Socket pin 12 > 4.0 V"); puts(" Socket pin 13 > 4.0 V"); puts(" Junction of"); puts(" D1, D2, and R1 < 0.8 V"); errmsg(" "); vppoff(); clockdown(); datareadable(); // AUTOFD, SLCTIN high //banner(); //puts("TEST 3\n"); //puts("With negative voltmeter lead still"); //puts("connected to pin 5 in the PIC socket,"); //puts("verify that pin 13 > 4.0 V.\n"); //puts("Next, insert a 470-ohm resistor into the socket"); //puts("connecting pin 13 to pin 5 and verify that"); //puts("pin 13 drops to < 2.0 V with the resistor in place.\n"); //errmsg("Then remove the resistor."); allpinslow(); datawritable(); // SLCTIN down dataup(); // AUTOFD up banner(); puts("TEST C\n"); puts("With negative voltmeter lead still"); puts("connected to pin 5 in the PIC socket,"); puts("verify that the junction of D1, D2, and R1"); puts("is < 0.8 V."); errmsg(" "); allpinslow(); datareadable(); // SLCTIN up dataup(); // AUTOFD up banner(); puts("TEST D\n"); puts("With negative voltmeter lead still"); puts("connected to pin 5 in the PIC socket,"); puts("verify that the junction of D1, D2, and R1"); puts("is now > 4 V.\n"); errmsg(" "); banner(); puts("This completes the voltage test sequence.\n"); puts("You should also check the cable from PC to programmer."); puts("It should be relatively short (under 2 feet) and have"); puts("all necessary pins connected (serial cables don't)."); errmsg(" "); allpinslow(); exit(0); } void load() { FILE *f; banner(); printf("File to load: "); strcpy(FNAME,getstring()); f = fopen(FNAME,"rt"); if (f == NULL) { errmsg("Unable to open file."); FNAME[0] = 0; return; } loadhexfile(f); fclose(f); errmsg("Loading complete."); if (CUSED == 0) { banner(); puts("Caution: HEX file did not contain a configuration word.\n"); puts("The following settings will be used:\n"); puts(" RC oscillator"); puts(" Watchdog timer disabled"); puts(" Power-up timer enabled"); puts(" Code not read-protected\n"); errmsg("You can specify other settings in the assembler."); } else if (CMEM[0] != (CMEM[0] & CMASK)) { banner(); puts("Caution: Configuration word appears to contain invalid bits.\n"); puts("Your program may have been assembled for a different"); puts("type of PIC. Check device selection carefully."); errmsg(""); } } void selectdevice() { banner(); puts("Devices supported:\n"); puts(" C PIC16C84"); puts(" F PIC16F84"); puts(" 3 PIC16F83\n\n"); puts(" T Test the programmer circuit\n"); getchoice("C,F,3,T"); switch(CHOICE) { case 'C': DEVICE = PIC16C84; PSIZE = 1024; CMASK = 0x001F; DEFAULTCONFIG = 0x001B; break; case 'F': DEVICE = PIC16F84; PSIZE = 1024; CMASK = 0x3FFF; DEFAULTCONFIG = 0x3FF3; break; case '3': DEVICE = PIC16F83; PSIZE = 512; CMASK = 0x3FFF; DEFAULTCONFIG = 0x3FF3; break; case 'T': troubleshoot(); } } void erase() { int i; vppreset(); printf("Commanding PIC to erase ID, configuration, "); sendcmd(LOADCONFIG); senddata(0x3FFF); for (i=7; i>0; i--) sendcmd(INCREMENTADDRESS); sendcmd(1); sendcmd(7); sendcmd(BEGINPROGRAMMING); delay(20000); sendcmd(1); sendcmd(7); printf("program, "); progcycle(ERASEPROGRAM,0x3FFF); // is the data word necessary? printf("data..."); progcycle(ERASEDATA,0x3FFF); // is the data word necessary? allpinslow(); puts(" Done."); waitkey(); } void program(int mode) { word i; banner(); if (PUSED+IUSED+CUSED+DUSED == 0) { printf("Load a file first.\n"); goto finish; } vppreset(); printf("Program memory: "); if (!programall(mode,PMASK,LOADPROGRAM,READPROGRAM,PMEM,PBASE,PUSED)) goto finish; sendcmd(LOADCONFIG); // from here on we're in config/ID memory senddata(DEFAULTCONFIG); // loadconfig requires an arg, here it is printf("ID memory: "); if (!programall(mode,IMASK,LOADPROGRAM,READPROGRAM,IMEM,IBASE,IUSED)) goto finish; for (i=0; i < CBASE-IBASE-IUSED; i++) sendcmd(INCREMENTADDRESS); // get to config memory printf("Configuration memory: "); if (!programall(mode,CMASK,LOADPROGRAM,READPROGRAM,CMEM,CBASE,CUSED)) goto finish; vppreset(); // Reset address counter in PIC to 0 printf("Data memory: "); if (!programall(mode,DMASK,LOADDATA,READDATA,DMEM,DBASE,DUSED)) goto finish; puts("Programming complete.\n\n"); puts("For production-grade work, you should now verify"); puts("the PIC at the maximum and minimum values of Vcc."); finish: allpinslow(); waitkey(); } void queryexit() { banner(); allpinslow(); puts("Are you sure you want to exit?"); getchoice("Y,N"); if (CHOICE == 'Y') { banner(); errmsg("You may remove the PIC from the socket now."); exit(0); } } void menu() { allpinslow(); // Clean up after aberrant routines if any banner(); puts(" L Load HEX file"); puts(" S Select type of PIC"); puts(" E Erase PIC"); puts(" P Program PIC"); puts(" V Verify PIC\n"); puts(" X Exit program"); getchoice("L,S,E,P,V,X"); switch(CHOICE) { case 'L': load(); break; case 'S': selectdevice(); break; case 'E': erase(); break; case 'P': program(PROGRAM); break; case 'V': program(VERIFY); break; case 'X': queryexit(); } } main() { FNAME[0] = 0; // no file is presently loaded selectport(); allpinslow(); selectdevice(); // mandatory banner(); puts("You may insert the PIC in the socket now."); errmsg("Be very careful not to insert it backward."); while(1) menu(); return 0; } |
| comentario del autor | Mie Abr 16, 2008 9:15 am | |
Saludos y muchas gracias por la ayuda. Que tengas un excelente dia |
