| comentario del autor | Mie Mar 21, 2007 9:33 pm | |
| sin valorar | Vie Mar 23, 2007 4:28 pm | |
3 luces rojas tienes que ser muy precavido antes de meterle la pistola de calor esa porque primero necesitas saber que error te esta presentando la consola aqui hay unos errores these are the codes we know so far... Please contribute if you know of new codes that are not part of this list. ============================= Sections 1, 2, 3, and 4 are flashing red - The AV cable cannot be detected / \ \ / THINGS TO TRY 1. Make sure that the AV cable is correctly connected to the Xbox 360 console. 2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console. 3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again. 4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available. ============================= Sections 1, 3, and 4 are flashing red - General Hardware Failure / \ \ / The specific type of hardware failure can be determined by a "hidden" error code * Turn the xbox 360 on, and wait till the 3 red lights are flashing. * Press and hold the sync up button (the small white one), while holding that button press the eject button. * The LEDs will now blink the first number in the code (as described below). * Release the eject button and press it again. * The LEDs will now blink the second number of the code. * Release the eject button and press it again. * The LEDs will now blink the third number of the code. * Release the eject button and press it again. * The LEDs will now blink the forth number of the code. * Release the eject button and press it again. * The LEDs will go back to the 3 red flashing lights. You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash. Here is how you interpret the LEDs to get the code number: * All four lights flashing - 0 * One light flashing - 1 * Two Lights flashing - 2 * Three lights flashing - 3 0001 power supply problem 0002 power supply problem ... 0010 over heating 0011 over heating 0012 over heating 0013 over heating ... 0020 (Not yet known, possibly overheating) ... 0022 GPU Error / GPU Overheating ... 0102 unknown error - littereally means the console does not know what is wrong. possibly a short or cold solder joint somewhere (2 reports of people repairing this, one was removing moisture build up inside the console, the other used a hot-air rework to reflow the BGA Ram chips) ... 0110 (Not yet known) ... 1022 (Not yet known) yo tengo por ahora el error 0102 que aparece como desconocido pero hay unas posibles soluciones como pasar la pistola de aire caliente y resoldar los chips de ram de la 360 que son marca samsung y tambien investigue que se pueden arreglar con un Borrador de nata y presionar la ram contra la parte metalica de la 360 Nota esto es en el caso del error 0102, he visto muchos tutoriales que lo arreglan con la pistola de aire caliente resoldando el gpu a los lados pero solo hacer esto si se esta bien seguro de que esta es la falla o el error ya que se puede dañar el gpu por exceso de calor bueno colega espero le sirva un poco estos comentarios y cualquier cosa comenta. ah si no entiende bien el ingles de arriba basicamente es prender la 360 esperar a que las 3 luces aparescan, luego espichar un pequeño boton que esta ahi al ladito mantenerlo presionado y espichar el boton de eject y ahi le mostrara el pimer digito del codigo de error, soltar el boton de eject y espicharlo otra vez y aparecera el segundo digito del error y hacer lo mismo hasta que aparescan los 4 digitos del error y luego de hacer esto vuelve a mostrar las Bonitas 3 luces rojas de "navidad" ve que buen invento cuando venga la navidad poner el 360 en la ventana para que brillen esas 3 luces¡¡¡¡¡ y vean que las consolas no solamente sirven para juegar jejejejeje. yo cuando tenga tiempo voy a hacer lo del borrador en las 4 ram donde esta la x que sujeta el disipador del gpu a ver como me va segun el que puso este articulo es para el caso del error 0102. y asi comentarlo a todos por aqui [/b] |
| sin valorar | Mar Mar 27, 2007 4:19 pm | |
| sin valorar | Sab Sep 22, 2007 2:46 pm | |
A mi me pasó igual y te comentare que hice con el problema de las luces rojas: Primero quiero aclarar q no se nada de electrónica y todo lo hice siguiendo indicaciones de otras personas que han tenido el mismo problema. Es importante que si alguien adquirió la consola en un centro autorizado, y tiene su Xbox original sin modificaciones para que lea juegos copia, llame al servicio técnico de Xbox http://www.xbox.com/es-CO/support/contact/, que ellos te remplazan tu Xbox por una nueva. En mi caso, yo vivo en Btá Colombia, la consola la adquirí en USA, y adicionalmente la mande modificar para leer juegos no originales, por tal, me tocaba pagar para que le colocaran el software original, y sellos nuevos, luego enviarla a los estados unidos, y esperar que ellos me la repararan, y volver a pagar para envío a Bogotá, eso si no se daban cuenta que había sido modificada. Esto me costaba más q comprar una nueva y mas riesgoso. Por lo anterior decidí meterle mano, que igual ya estaba dañada, no perdía mucho. 1 – La abrí siguiendo el siguiente tutorial http://www.modchipstore.com/support/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=173 y este tutorial http://www.xbox-accessories.com/instructions/disassemble360.html 2 – Una vez abierta la Xbox, procedí a limpiar la silicona esparcida en los disipadores y en los procesadores, esto usando un copito y alcohol, y con mucho cuidado frotando en círculos, hasta que quede totalmente limpio. 3 – Luego agregue la pasta térmica, un punto sobre los dos procesadores. 4 – Como no tengo pistola de calor, y además me da miedo esas cosas, decidí no aplicarle calor de esta forma. 5 – Armé la Xbox completamente, y efectivamente aún no funcionaba. 6 – La envolví en la toalla, esperando según dicen los que saben que el calor mismo generado por la Xbox volviera a unir lo que estaba desunido. Lo dejé aproximadamente 12 a 15 minutos, luego de este tiempo, le quité la toalla y 20 minutos enfriando. 7 – Al prenderla nuevamente funcionó… la he probado esta semana por periodos no mayores de 1 hora, hasta el momento anda bien |
| sin valorar | Mie Oct 03, 2007 1:09 am | |
saludos. |
| sin valorar | Lun Nov 26, 2007 5:19 pm | |
he reparado muchas falla de tres luces y sin ningun problema ha vuelto fallar. tengo la formula de reparar... si desea consultar mi correo es ruiz_766@hotmail.com, ruiz_766@yahoo.com.mx. me dedico a reparar todo de los video juegos con experiencia de mas de 6 años |
| sin valorar | Dom Mar 02, 2008 3:04 am | |
su máximo de temperatura es de 5ºc después de jugarla 5 horas seguidas si lo quieren ver les dejo el url de mi video de youtube y porfa califiquen el video y dejen sus comentarios http://mx.youtube.com/watch?v=Qlcu5f97dUA esta es la primera modificación http://mx.youtube.com/watch?v=QqFW3ll4cTE esta es la última modificación la definitiva Suerte con sus consolas. mi msn richard_091186@hotmail.com ojo después de repararlas con la pistola de calor olvídense de cerrar su consola de lo contrario morirá muy pronto otra vez. Les repito no pasa de los 5ºc después de haberlo jugado 5 horas. PARA LOS Q DICES QUE LOS VENTILADORES QUE TRAE DE FABRICA EL XBOX 360 SON BUENOS LA VERDAD QUE NO LO ES. SERIAN BUENOS SI FUERAN MAS GRANDES SABEN CUAL ES EL PROBLEMA DEL XBOX 360 EN QUE TIENE VENTILADORES DE EXTRACCION PERO NO HAY NINGUN VENTILADOR QUE REFRIGERE EL GPU QUE ES EL QUE MAS SE CALIENTA TAL COMO LO HACEN EN LAS PC CON VARIOS NUCLEOS NO SE POR QUE EN VIDEOS NADAMAS SE DEDICAN A VENTILAR EL CPU ESE CASI NO CALIENTA. SE CALIENTA MAS EL GPU POR QUE ESTA ABAJO DE LA UNIDAD DE HDMI. ALGUN DIA DESTAPEN SUS CONSOLAS Y TOQUEN LOS DICIPADORES Y SABRAN POR QUE LES SALEN ESAS FAMOSAS 3 LUCES ROJAS DE LA MUERTE |
| sin valorar | Vie Mar 21, 2008 7:49 pm | |
PRENDES LA CONSOLA CON LAS 3 LUCES ROJAS LE PONES UNA TOALLA ENCIMA Y LA DEJAS QUE SE CALIENTE POR 20 MINUTOS LA CONSOL SE CALENTARA MUCHO DESPUES DE LOS 20 MINUTOS LA APAGAS Y LA DEJAS ENFRIAR A TEMPERATURA AMBIENTAL Y DESPUES DE FRIA LA PRENDES Y VERAS QUE DESAPARECIERON LAS 3 LUCES ROJAS PERO EL PROBLEMA TAMBIEN PUEDE CER LA FUENTE O POR QUE L AS INSTALADO EL CHIP SUERTE AMIGO Y CUALQUIER DUDA AQUI ESTA MI CORREO CEEL890@HOTMAIL.COM |
| sin valorar | Vie Mar 21, 2008 9:20 pm | |
estas ahn sido las midificaciones de mi consola por que cada ves se calienta mas y ya la e reparado mas de 5 veces y solo asi ya no se calienta mas de 5ºc en el gpu y el cpu http://mx.youtube.com/watch?v=aOBDsm2oooE http://mx.youtube.com/watch?v=QIekj2dn4gA http://mx.youtube.com/watch?v=QqFW3ll4cTE http://mx.youtube.com/watch?v=Qlcu5f97dUA |
| sin valorar | Mie Jul 29, 2009 2:10 am | |
amigo yo te digo q en este foro no encontraras la solucion estas persona de la comunidad estan bloqueadas por esta falla algunos dicen que la falla es el sobre recalentamiento otros q la mala soldadura mientras dicen unos y otros hacen lo que dice los foros pero que pasa ! si lo reparan pero en menos de un mes buelve la falla y eso es porque no componen el origen del problema dicen resolda el gpu con pistola de calor y ponle pasta y pasa a 12v los ventiladores internos ok hacen eso pero la falla sigue ok luego dicen quita las x ok lo hacen y en menos de 3hora de juego sigue la falla mira yo soy tecnico tengo 20años mi padre lleba mas de 30años en esto y yo de chico siempre estube en el taller actualmente estudio y trabajo en el taller dedicandome a la reparacion de consolas de cualquier marca cuando empece llego esa falla al taller te dire que la reparaba y en menos de 2dias volvia con la misma falla y asi en mi caso encontre el origen del problema hace 4meses y que cres no fue la mala sondadura ,tampoco el sobre recalentamiento fue algo sensillo que no creeras y el costo de la pieza en mexico no sobre pasa los 20pesos jajaj neta mi correo es jorge_chido@live.com.mx agregame y te digo la falla con mucho gusto pero te aclaro deves de tener conocimientos en soldadura intermedio por que tendras que cambiar unos componentes de la placa base con este metodo e reparado unos 20 xbox360 con falla de 3luces rojas en 4meses y ninguno a buelto y no modifique los ventiladores a 12v ni quite las x ni agregue cooler _________________ |
| sin valorar | Mie Jul 29, 2009 2:12 am | |
| sin valorar | Vie Ago 14, 2009 4:03 am | |
ATENTAMENTE. JESUS LORANCA SENTIES. |
| sin valorar | Vie Ago 14, 2009 4:05 am | |
| sin valorar | Vie Ago 14, 2009 4:17 am | |
MUCHAS GRACIAS. A T E N T A M E N T E . JESUS LORANCA SENTIES. |
| sin valorar | Vie Ago 14, 2009 4:21 am | |
| sin valorar | Vie Ago 14, 2009 4:23 am | |
| sin valorar | Vie Ago 14, 2009 4:24 am | |
| sin valorar | Vie Ago 14, 2009 4:27 am | |
| sin valorar | Vie Ago 14, 2009 5:10 am | |
jorge luis calderon santo escribió:Si mejor pidele ayuda a ruiz ese compa si sabes no como tu que andas pidiendo limosna YA DEJA DE ESTAR DE OCICON MEJOR PONTE E BARRER EL TALLER DE TU PADRE QUE CON 30 AÑOS YA DEVE TENER MUCHA BASURA ENPESANDO POR TI JA JA. |
| sin valorar | Mie Sep 16, 2009 3:50 pm | |
| sin valorar | Mie Sep 16, 2009 3:51 pm | |
| sin valorar | Jue Sep 17, 2009 12:51 pm | |
| sin valorar | Mar Sep 29, 2009 10:31 pm | |
El ofrecer sus servicios de modo pago en un lugar donde se pone el conocimiento además jactándose de sus conocimientos en detrimiento de los de la gente del foro demuestra que es una mala persona. Por eso te digo ANDA A ROBAR A LOS CAMINOS. |
| sin valorar | Jue Oct 08, 2009 9:07 pm | |
" vendo la tecnica " y aparte si no le compras rapido se ofende nada recomendable este cuate aguas usuarios nuevos no les valla a mandar la tecnica de la resoldada jejejejeje |
